- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I just bought a KD-43XH8196 TV. I have tried to establish a Bluetooth connection between the TV and the
WH-CH510, but the TV cannot find the headphones. Where's the problem?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Jaffa74
If you have a look at your TV’s specifications you will see that the Bluetooth Profile required for any audio output by Bluetooth (A2DP) is not provided. However you may find something in the Play Store that will give you a work-a-round. Somebody else may give a recommendation.
- BLUETOOTH PROFILE SUPPORT
Version 4.2;HID (mouse/keyboard connectivity)/HOGP (Low Energy device connectivity)/SPP(Serial Port Profile)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Jaffa74
