Is it not possible to connect a bluetooth audio device (such as a headset) to a KD43XH8096 television?
(Website won’t accept my edit to the above - please read this instead)
This page is pretty clear your model range can’t do it:-
https://www.sony.co.uk/electronics/support/articles/00159290
Click the Android link there, to see that XH80s aren’t listed.
Your set has Bluetooth:-
but not the A2DP profile needed for headphones.
However, the problem is pretty easily, cheaply, and simply solved as per the advice I gave to @Lowestoftlass
It depends who you ask....😛
Yes, it is quite confusing. I have tried to shut down all other bluetooth devices as well as wifi, and turning bluetooth on and off, but it does not seem to like to register any of my headphones.
The question is if this is a bug, or it is not supposed to recognize them...
But it is pretty easily, cheaply, and simply solved as per the advice I gave to @Lowestoftlass
Thanks, that makes sense!
