I realized that if I turn off the AF8 and disconnect the power cable, when I turn it on, after a few seconds the image disappears (black screen) and sound. Changing the channel shows the image again. On the other hand if I only turn it off from the remote control this does not happen. I have the latest firmware version (I also happened with the previous one) and I have made a Factory Data Reset, but this has not solved the problem.
Hi theflyingdove,
That's strange. I'll see if i can find out anything for you. Someone else in the community may be able to help in the meantime.
Thanks,
Pascale
I've got a similar issue with my 65XF9005 and have sent Sony the following info...
I can now provide you with some further information which may help your engineers produce a resolution.
The 65XF9005 television which suffered from the picture blanking issue has been replaced by another 65XF9005 set. This set worked perfectly for 5 days without any picture blanking episodes UNTIL I performed a firmware upgrade to V6.5603.0175EUA. Now this replacement television has the same issue.
I have spent some time looking to find the cause and I can tell you the following :-
I hope this is of some help.
Hi theflyingdove,
Welcome to our community!
I've checked with Sony support and was advised that they are aware of the issue and it's currently under investigation and it should be resolved with the upcoming firmware version but unfortunately the release date for this update is not yet confirmed.
Regards,
Batee5
Hi @theflyingdove,
Just to add to the comment by @batee5. Your issue sounds somewhat familiar to me. However it could be that it might not be exactly what I think it is, namely the Samba Services Manager (SSM). To know for sure, you could try to restart the TV by holding the POWER button on the remote until you get the Shutting Down message. After the TV restarts, if you encounter the issue then it is the known issue mentioned by @batee5. In this case disconnecting the TV from the mains is not really the trigger for the problem, but the call process on the SSM during the Android TV boot-up.
The workaround for the time being would be to disable the SSM by:
Restart the TV by holding the POWER button until the TV shuts down. Let’s wait and see if things will keep working as expected.
Keep us posted!
Dutchice
