BBC iPlayer missing since Android TV v8 update
psellwood
New
I recently upgraded my Sony KD-49XD8305 to Android TV v8 and, whilst everything else continues to work, BBC iPlayer has disappeared and is no longer visible in the App Store.
I can’t find anything else online mentioning this issue and can only think that iPlayer hasn’t been updated to work with the latest OS yet.
Is anyone else having this problem? Does anyone have a fix or workaround?
45 REPLIES 45
profile.country.GB.title
Tonycv51
Contributor
I didn't think iplayer was visible outside of sony select pre Oreo tbh.
My 5 is the only one that's a normal Play store app.  For the rest that are youview linked and/or pre installed and only available in Sony Select you can sideload them from Hoshsadiq github.  They can then be added to favourites and the apps row, and appear in the apps list from the apps button
marane98
New
Clicked on Programming guide on my homescreen of X9305 - youview is there and iplayer is also tucked in this guide!
gbristow2222
New
Ive just bought a KD55XH9505BU which has twin tuners so you can record one programme whilst watching another. However as soon as you load 'Live TV & Catch Up' ie Youview it disables the recording function on the telly. Why cant you record programmes and still access catch up? I have an LG TV where you can record all day long and still download iplayer and ITV hub as apps. Why wont Sony allow these apps on Bravia except through Youview? Am I asking for the impossible here from a £1,000 2020 television?
Sceptic10
Explorer
And me. Have only just noticed. Has Sony given any advice?
Win_88
Specialist
Hi @Sceptic10
Do you have the same TV? Could you check which sw version you have on there by pressing Help - System information?
Win_88
Sceptic10
Explorer
Thanks. After several checks of all Settings I found that some had been changed by the update. In the end I got back to where I was before the update and now all is well
Win_88
Specialist
Glad to hear that @Sceptic10
I found this article on the Sony website, I think that's the setting you meant?
https://www.sony.co.uk/electronics/support/articles/00254818
Win_88
joporte87
Explorer
If you havce disabled YouView, reenable it and then see if IPlayer loads. Mine did straight away - I was trying to get my TV to record and that is why I disabled YouView - a YouTube suggested it.
Tags (1)
david.adamsztcjdm
Explorer
How do you "enable" youview?
david.adamsztcjdm
Explorer
Aha, so to find IPlayer you need to press TV and this opens TV in Youview, then press the blue button the press Players and there it is. Why oh why Sony did you let Google hide this away? You have seriously upset your British customers.
Now, where can I find ITV Hub, which also dissapeared and is not hidden with IPlayer. Did Google hide this somewhere else?
