So, will we finally get Bbc iPlayer support in time for the World Cup? Announcement coming imminently:
https://www.whathifi.com/news/bbc-4k-hdr-world-cup-confirmation-week-away
@jan.hansen957 wrote:
Simply untrue. I played the UHD in World Cup through Kodi. MPD-Dash file.
It is doable. I just don't get it. The 2017 and 2018 version consists of
the same SOC, doesn't they? A9F has a new SOC.
The XD80 isn't fast, but when Kodi can do it, Sony should have made an
effort for us. They clearly have not.
The 2017 Sony Android TVs still don't support it, even though Sony keep claiming they do, the only TVs which support it are the 2017 Sony non-Android TVs or the 2018 models. So its not just the XD guys left behind.
The XF has the exact same SOC as the XE yet Sony still can't get the XE working! I have yet another open case file with Sony for what its worth.
From my experience, apps have to be well optimized to properly cope with high resolution high frame rate content (2160p50/2160p60). They better use asynchronous data processing and tunneled playback via MediaCodec. Also Kodi exhibits occasional stuttering when playing back certain content (e.g. the Sony Camp Demo with 2160p60 @ 80mbps) over network on Sony ATV2 devices (and it is not a bandwidth limitation).
@Kuschelmonschter wrote:@From my experience, apps have to be well optimized to properly cope with high resolution high frame rate content (2160p50/2160p60). They better use asynchronous data processing and tunneled playback via MediaCodec. Also Kodi exhibits occasional stuttering when playing back certain content (e.g. the Sony Camp Demo with 2160p60 @ 80mbps) over network on Sony ATV2 devices (and it is not a bandwidth limitation).
Yeh, I agree there, I noticed that with Smart YouTube TV it tends to pre-buffer the content to maintain the 2160p60 performance, something the regular YouTube app appears not to do, and hence is a stutter fest. You obviously can't do that with Live content.
The only issue I have with the argument is both the XE9005 and XF9005 share the same Mediatek SOC, the XF9005 has confirmed working iPlayer UHD support (although granted, I don't know what the performance is like, the BBC have certified it so they must be fairly content).
However, saying all that the PS4 support for iPlayer UHD is not exactly stellar imo (as it suffers from microstutters to my eyes which the BBC deny) and I had to force the TV to do motion compensation (very aggresive motionflow and filmmode) to get a smooth presentation in the World Cup.
It’s all working now.
Launched iplayer on xe9005 2017 model today and “Dynasties” is available in UHD and looks great . Test loop available as well. Merry Christmas
Makes you wonder if this was the original problem and it will never be fixed with HDR.
whilst I havent tried or tested it yet but on my other android devices pressing the home button twice brings up a task manager and lets you close tasks down so if you couldn't stop the dynasty feed you could try to force the app to close like that hth
