Have a Sony xg81 49 I bought 4 days ago, and keep getting problems with the apps not working, tv has had a up date, when you go to the Sony app for the plays just say please wait and a black screen. Netflix works on it. But have to keep turning the tv off and back on for it to work.
It’s done it 3 times day and yesterday, used to have a Panasonic but that broke after 4 years and couldn’t get the parts so bought this one, The sound and picture on Panasonic I’d say was better than the Sony but hopefully it will last.
Hi there,
Have you tried a factory reset?
Best wishes,
M
Hello, I sent tv back as was not happy with it, it kept going of WiFi and really slow in apps. Also was not very good in a bright room or dark room. Even after a update and factory reset it was the same,
went out and bought a Samsung tu 8500 so much better than Sony.
