From the home page under "Inputs" ( Ingressi in the italian version) the AV 2 port is grayed out and if I click on it nothing happens. The same if you click on the DIGITAL/ANALOG button on the remote control, the item AV 2 is skipped.
Hi Luigi,
Thanks for reaching out to us. There's some useful information on this help page that may help you with your AV 2 question. Let us know how you get on.
Cheers,
EdwinaU
Thanks for replying but it does not tell me why the second av receiver does not work. If the port is there why can't I use it?
Hi Luigi,
Could you please let us know what it is that you've connected to AV2?
Thanks,
Owen
I just found the solution here: https://community.sony.com/t5/Television-Apps-Widgets/I-can-t-get-AV-input-2-to-accept-a-signal-AV-i....
Actually nothing was connected as for the other inputs, but only AV2 was greyed out
Hi, that page is now unavailable. I have the same problem with an 8305. Can you give a description of the solution assuming there is one.
Tansea
