x
Antivirus for Android TV needed?
SOLVED
profile.country.GB.title
nick.connor
Member
Do I need to install antivirus on a Sony Bravia with Android TV?
1 ACCEPTED SOLUTION
Accepted Solutions
nick.connor
Member
Thank you for the promt response.
4 REPLIES 4
Anonymous
Not applicable
Hi there
No, not needed.  Just dont install apps that you are not sure where it came from.  But Ive not heard of a virus on  Android platform.
nick.connor
Member
pajo100
Member
I would always recommend using anti virus on anything connected to the Internet.
Anonymous
Not applicable
Hi there
Normally I would agree with you.  Firstly I dont think there is an anti-virus/malware app for Android TV.  Secondly, you would have to specifically install a rouge APK or browse dodgy websites via the TV that is capably of delivering a virus payload specific to the Android TV operating system.
If a virus/malware is man-in-the-middle attack happens on the Android TV, its probably because your home network has been broken into / hacked.  Many routers these days come with Network protection and Anti-virus/malware protection.  Such as mine (Asus DSL-AC68U):
undefined
Added to that, some (many?) ISP's these days include network filtering and anti-virus protection from ISP level as well - suggest enabling these as well.
Last bit of advice - ensure that your Wifi password is set and 'strong'
