Having issues with this TV, the moment its £1250 I’ll never see again!
I currently am running the TV via LAN, and connected to my router is a WDmybooklive, The TV takes forever reading the HDD in the Sony Video App, and then comes up please try again later, sometimes it will even say the NAS drive is turned off, however i can still access it on my IPAD
is anyone else experiencing these issues?
No problem. Open Kodi and go to Videos>Files>Add Videos>Add Video Source>Browse
From there, you should get a list of sources which should include your drive. Let us know how it goes.
Do you have the same issue if you install Kodi?
sorry pal, without sounding thick..... i have downloaded Kodi, but how do i access my NAS Drive?
Thanks Pal,
worked for me perfect!
dont suppose you have links you can send me to to where to get the best Kodi presets?
Tom
Glad to hear it's working.
Hm it's hard to say as it depends on your set up. To make it run well, having a well organised file system is the first thing. I use the Fire TV skin myself but have used Amber in the past.
