Is it OK to expect Android Oreo on 2017 Sony Android TVs?
Rolling out tomorrow. FINALLY
Here's official video:
Hi guys, I'm here now in Turkey and 00:27 hours and dates from 30 February, so why are you still did not support Oreo update their sites?
Also available in the UK.
In Czech Republic OTA wasn't available, but I've downloaded Oreo and install it via USB without any problem. Oreo looks great.
friends, I've installed the oreo update with usb, but I'm not happy at the moment, if you say why; 1080p and 4K videos that I play before do not open now, there is also a problem with DLNA streaming 😞
This is a known issue, that everybody is complaining about in the US. I guess I'll just stick with Nougat, until they find a solution.
Yes. The Video app is totally broken. It hardly plays anything and often puts the TV in an inconsistent state. Kodi is fine though. You just have to disable DTS and DTS-HD passthrough which the TV pretends to support. It however does not work.
I really don't understand I'm testing all my 4K demo videos with high bitrate and al movies everything on external hdd (not even usb 3.0 but the older 2.0) and everything is working flawlessly...
I did a factory reset after update...
