Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
@Shodney wrote:Since we're all messing around in the developer settings, may as well try this:
https://www.reddit.com/r/bravia/comments/69q9fe/performance_tip_limit_background_processes/
I've been running like this for a week or so and, early days, but I haven't had an "[APP] has stopped working" popup since. I used to get one or two of these a day - whether it's coincidence or not that these have stopped I don't know.
Can't say I've noticed any general speed improvements otherwise though like others are saying. Still has laggy animations, stuttering and such.
Actually it has speeded things up for me in general. The only odd thing I've noticed is opening Netflix makes the desktop white for a split second and then Netflix opens (quicker than it normally does)
OK, so after reading all this comments about this infamous update, today I finaly decided to do it.
BTW, my TV is KD-55XD8505, so obviously 2016 European model.
Update done OTA wireless, took about 10 minutes all together. I haven't done a factory reset afterwords.
First impressions:
1. The whole system works significantly faster
2. Picture is deffinitely brighter and sharper (all my picture settings remained the same after the update)
3. HDMI inputs work perfectly and changing the sources works also much faster than before
So far all positive!
Let's see what happens in the next couple of days.......
OK, first bug after the update.....made me laugh, have to admit
I started Kodi on Beelink GT1 Android TV Box and then after maybe 30 seconds I suddenly got pop up with the message Netflix stopped working and another one with Google play stopped working. Hilarious
Sony people, wake up, you just don't have a clue what you are doing
@bbrks011 wrote:OK, first bug after the update.....made me laugh, have to admit
I get those and youtube has stopped workin, when I'm not even using it.
I would love to know which idiot is doing the firmware?
sure, YOU are not using it. But go to settings-apps and look at all those (cr)apps that are running after reboot. Basically, everything that is installed starts at boot. Just disable everything that you don't need and that can be disabled.
@kinggo01 wrote:sure, YOU are not using it. But go to settings-apps and look at all those (cr)apps that are running after reboot. Basically, everything that is installed starts at boot. Just disable everything that you don't need and that can be disabled.
Why would anyone do that?
And reporting bugs is a good thing. It's just that sony devs are very crap with android TVs.
I won't be buying from Sony ever again.
