has.anyone.hade.the.same.problem.as.i.am.having.trying.to.get.the.problem.with.the.amazon.app.resolved.i.have.tried.sony.they.tell.me.to.get.in.touch.with.amazon.but.when.i.get.on.to.amazon.they.refer.me.back.to.sony.the.problem.is.the.picture.keeps.juddering.and.the.sound.goes.in.and.out.this.has.been.going.on.since.i.got.the.tv..in.feb.2017.i.just.want.it.resolved
This is your 3rd thread with exactly the same title and content...
the.reson.i.keep.asking.is.than.i.cant.seem.to.get.a.solution.to.my.problem
HI there
At the moment there are various issues with the Amazon app, which is listed in the bugs/issues list HERE.
Your issue seems to fall in the Juddering issue. At present time there is no fix.
thanks.but.the.problem.is.still.there.i.phoned.sony.at.02073652810.i.am.still.wating.for.them.to.phone.back.do.you.know.if.there.is.a.phone.number.for.the.tech.team.also.when.i.play.the.amazon.app.on.my.blu-ray.player.and.fire.tv.box.there.is.no.problem.the.picture.quility.is.far.supirior.to.the.picture.i.get.on.the.tv.app
@stewartgordon4 All right. I am sure I am not the only one wanting to ask this: why do you keep writing dots instead of spaces? It makes it hard to read what you write.
Hi there
You have phoned the correct number for Sony - this is the only number.
As I mentioned above, there are various issues with the Amazon TV app at the moment. The reason they are still on the bugs/issues list is because they remain un-resolved. As you have other means of using the Amazon app (i.e. Bluray player and Fire TV box), I would suggest using those apps at this moment until Sony/Amazon resolved the current issues.
Sony is aware of these issues by the way - but I am unsure on who is ultimately responsible for resolving them (probably a combination of both).
