How do I disable this
So annoying when it regularly pops up
Yes, same with me as well- with Sky
No, you have no idea how a Sky/Now router works. Go and patronise somebody else.
Yeah that's right. Troll off.
Just can't help some people
I've tried the previous tips - soft and factory reset, network not broadcast time, latest firmware version, reset router etc. Seems like most people fixed issue but those with Sky/Now broadband/router haven't. This is one you might not have tried, menu changed a bit but found in apps.
I am just going to turn wifi off when watching sky and turn on for netflix etc. Seems odd to watch a streaming service and tv says it can't connect to wifi......
Wish I hadn't switched from Plusnet....
Update Android TV Core Services application from the Google Play Store
I’ve been with Sky for years and very happy with the service I’m getting but this annoying pop-up has only been regularly errrr popping-up, relatively recently
Hey PaulinBont, have you tried the update for Bravia Core? Also, what's the software version?
