I cannot find a way to add new apps to my Home Screen.
i have recently subscribed to the new Disney Plus channel and want to put in on my tv.
Help, please?
Find the Disney+ icon in the Apps folder, long press on it and choose Add to favourites, and it will appear at the end of the favourites bar!
If its not installed on the Tv press apps on the remote control, press get more apps on screen (the top button on screen). Disney is the first of the featured apps so select it to install
Unfortunately, there is no Disney app icon in the Apps folder!
i cannot find a way to download the app?
There is no apps on the remote!
My screen
Sorry I have the old remote on my XF
I assume you've got a row with Apps on the home screen? If so on that row press left on the dial to go left onto the apps symbol, press enter and then get more apps
is there Disney app for non android models? Think not.
Going to the far left in Apps, I can only get to the first apps in the folder. I cannot get onto where it says “Apps”!
Why wouldn’t there be? It is an International channel platform!
