I have the BRAVIA KD55X8509C Smart 3D Ultra HD 4k 55" TV and now wish I hadn't had purchased it!!!!
I have been unable to find 3d glasses ANYWHERE!!!! I spent £1500+ on a TV looking forwards to trying the 3D out and all I can see is a £50 pair on the Sony site. I need 4 pairs so need to spend another £200!!!!! When you look online at, say Samsung 3D glasses, you can buy glasses for £30 (and they're active 3D, too!)
I'm disgusted. I'll be contacting Sony / Currys about this to get a refund on the TV....
Hi did you ever get these working with your TV??
I have the same TV and was wondering if the above glasses worked
I bought mine from this website.
Hope it helps
You can use glasses HAMA 3D works perfectly!
Hi Kevin
Do the 3D Glasses you recommended work on 3D Sky channels?
Appreciate your feedback.
Many thanks
I have the same problem xbr-55x930D THE NEWEST MODEL! $1500+ and 3d does not wordk with new active glasses. Very dissapointed with expensive sony tv.
