Hi to all,
I did update yesterday and I am disapointed. After update many apps lost acces to my external hard drive with message "path is not found or invalid". Only way to fix it is format HDD to FAT32. But I need to access to file larger than 4 GB so this solution is unusable to me. Does anybody have the same problem or idea how to fix it anyway? Thanks a lot in advance.
I am experiencing a similar issue. Apps are not able to write to NTFS and exFAT anymore. FAT32 works.
