I have strange problem with my 65XE9005 and bluetooth headphones (Bluedio T4S).
I am able to pair headphones and then everything works fine.
But after turning headphones off and on again the connection requires going into Bluetooth settings of the TV and picking "Connect" on the headphones (visible in paired devices).
Then again everything works fine until I turn off headphones.
Is there a way to make headphones automatically connected just as I turn them on?
Hi there,
I would recommend getting in touch with the Headphones manufacturer for further advice on this.
Best wishes,
Sean Mc
@Sean_Mc schrieb:I would recommend getting in touch with the Headphones manufacturer for further advice on this.
Why? It is the TV that is responsible for finding and auto-connecting nearby Bluetooth audio devices..
