Hi all,
Before I factory reset my Sony KD75XH8096BU that received the Android 10 update this week (and then another update - I am now on v6.6152 - https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh80xx_x80xxh_x81xh-series/kd-75xh8096/so...
I was wondering - am I the only one experiencing lag when browsing the menus? Especially the setting menu is a massive downgrade in comparison to Android 9 (why is it fullscreen now?)...
Also, some setting menus take minutes to load?
I have video proof that I could upload if needed...
A video would be very helpful thank you, something along what I did below. It is possible updating FW entailing Android 10 might have cleared Android cache, which would take a short while to re-cache. A factory reset and then reinstall apps and re-enter user/passwords etc, is a PIA but might help.
I put up a video some years ago about annoying power consumption messages which was quickly picked up by HDTVTest which I think helped contribute to Sony modifying subsequent FW updates:
Hi there,
Please find the video below:
https://youtube.com/shorts/YJQ3Zz_pgU0?si=AuFrvTTOt3XlK_5U
Indeed, I ran a factory reset which solved the issues - even though I still think that Android 10 is a bit slower than Android 9 (at least on my TV).
Many thanks
Hey @TVANCleeds
Sometimes the electronic device needs to be reset after the update, so it would be placed properly without any glitches. As sometimes the TV lags or glitches after installing a new software, when you do a factory reset it rectifies the glitches caused by the software update and reinstall the update again.
