Hello,
I got the mentioned TV which is connected to XboX One S . I tried all the settings off/on and nothing happens.There are threads to turn off the advanced contras setting / eco mode and etc. The screen continues to dims and brighten up at random.
Please help.
i think i found it. Exclusion method ! on the xbox there's an option colour depth - PC RGB .. i thought sony 4k hdr tv support it but with it the TV went "nuts" .
Thanks in advance,guys!
Hi there
Without knowing all your settings, its hard to know where to advise. I can only suggest the following:
Cool - glad you found it
