I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
Yes i have on two tvs i had first exchanged second was as bad so went for a Panasonic,it is not the firmware it wiped my sticks over 3 months ago it did it serveral times,i went you watch content on stick nothing on it and had to reformat it on computer.
Sorry but other than the german excel file do we have something bit more serious with the matrix of product/fw/bug? And possible solutions or work around?
I've been collecting my issues and I also tried to send a pvt message to you @Anonymous but I didn't have a reply.
And thos thread is getting annoyng, more complains and futile discussions than proper bug report and help.
How many post do I have to write to start being able to create a new structured thread?
It seems I got enough permissions to create the new thread.
I started, it will take some tome to load the content.
Thread whit the list of issues and solutions
The good 'ol @Anonymous who may I add really shouldn't leave this forum due to the worthless comments of some insignificant types, has already started a thread soley for reporting the faults with these tv's...
The spreadsheet posted by @Anonymous has been replaced by a simpler Survey Monkey page here
Easy to use
NOTE: If you entered data in the old spreadsheet, you do NOT have to repeat the report, the data has been transferred
Hi
sony 55 8509 owner here. I've got currys to agree to a refund due to the issues posted here.
anyone recommend a replacement at similar price range?
I'm just going to buy a fire stick and use that for kodi etc...
@frogger38 I speak 2.5 languages but German is not part of those...
elraouk +1.
please keep to the origional standards guys to make it easier to manage.
there is already a locked thread on issues in the main televisions section and also the excel spreadsheet was in google cloud therefroe straight updates/saving direct back to the owner. i used this last night and it was being populated.
Edited to correct myself - the spreadsheet has been replaced and is now a survery having just opened the spreadsheet again. Please use the survey link (which is now detailed in the origional excel spreadsheet if you happen to open it)
