- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
2015 Bravia Android TV Issues
I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPad
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
X8509 I turn tv on and when it starts there is a blank screen and sound from whatever source I was watching it happens whether I am using my receiver or just the TV
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What a mess my kdx658509c . Was ok before update. But
Now
Blank screen after turning on for 20mins
No casting
Seems no up scaling to 4k from sky hd
Image ruined all colours blown
Faces look tangoed
Have factory reset no better.
I phoned Jl today to start returning this great panel but broken not fit for purpose tv
Shame on you sony.this firmware update is a unfortunately unforgivable
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all
I have added the blank screen and the continued lip sync issues to the current faults and issues list. Any updates recieved will be posted back in this thread.
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2040020
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, Yes I did. do I need to do a factory reset after firmware update?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Anonymous
Yes I did. Do I need to factory reset?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
In the last days after the update i see that the picture is not as smooth as before. when there is a quick movment on the screen there is a litle lags (even when i just watching regular tv) anyone feeling like me???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try going to Picture settings and changing "Auto Picture Mode " to "Auto (24p sync)". Even if it is already set, select something else in the drop down like "Auto " then reselect Auto (24p sync). Helped me when I had juddering. Worth a try!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too noticed a lip synch issue for a video. But after the third attempt it appeared to be fine. i noticed this when i was playing a video fro my hard drive.
