I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
It's a Mediatek MT5890, ARM Cortex A17 cpu-cores and a Mali-T624-gpu.
You can use a tool like Teamviewer for AndroidTV to figure out what CPU is in an Android device
@tweety2b or anyone help
How do I find out what the processor is in my KD49X8305CBU
Also on Sony's website for this tv is states there will be a firmware update in Oct for Freesat
Is this possible as I thought once a tv has 1 tumer that is it.
We do have something called preffered satelite and have put that on, but it is a nightmare there are 100's of channels, none in order like 10 BBC one's etc, we tried to move them around and put the rubbish ones far back but will not work properly, we tried to delete the useless ones, but the space and channel number still appears, also there is no info showing on the guide so you have to guess what is on the tv
This was the teason we bought this make for the "freesat" but were not told about the lack of tv guide info or the 100's of duplicated tv channels
I have only had this tv a day and am beginning to wonder why I bought it. I am thinking of taking back this tv and just going back to my old Panasonic tv until companies get tv's sorted before they release them.
We had 2 Curved Samsung 6510 tv's and those had awful lip sync issues on both Freesat and freeview. Luckily we had our TV's from John Lewis
I am in the same boat in regards to no guide for UK satellite although mine does order the channels. BBC1 HD, BBC2, ITV, CH4 etc so there is definately some kind of support.
Can you provide the link where it says there is an update for freesat in Oct?
Daniel
