Hi quick question is there going to be a update to allow the Sony x94j to use 1440p at 120hz as the PS5 has had an update to allow 1440p....???
Hello @D-Law81, that's because the TVs don't feature 2k resolution, it's either 1080 or 4k which is supported by these models
I looked yesterday and shows all screen formats but 1440p.. says not compatible.
Proof it showing not compatible...???
Just checked specs and it says no 1440p on x90/94j TVs..? Why.
Is there going to be a update to fix this.?
