Would it be possible to record GPS data using the remote controller with a Sony a6000 camera?
¡Resuelto! Ir a solución.
The only way to find out is to try them as the functionality isn't advertised by Sony.
Hi @antxon001
That remote isn't compatible with your camera. You can find the supported ones here: http://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=ILCE-...
I don't think the remote will help record GPS data though.This is possible using Sony Imaging Edge Mobile on some alpha cameras, but not the 6000.
Win_88
Hasta donde tengo entendido el control remoto Sony RM-LVR2 solo es compatible con las action cams de Sony y con dos o tres dispositivos mas pero obviamente no lo es con la a6000
http://support.d-imaging.sony.co.jp/www/cscs/accessories/index.php?lang=es&area=gb&mdl=RM-LVR2
La a6000 si que es capaz de comunicarse con el TM-LBR2V. Lo he comprobado, y es capaz de visualizar la imagen y activar la grabación de video o la toma de fotos. Por eso pensaba si sería posible grabar los datos GPS, ya que en teoría tampoco era posible enlazar los dos equipos y sin embargo funcionan.
The a6000 is capable of communicating with the TM-LBR2V. I have checked it, and it is capable of displaying the image and triggering video recording or photo taking. That is why I was wondering if it would be possible to record the GPS data, since in theory it was not possible to link the two devices and yet they work.
