I have an a850, a77 and HVL-F58AM flash unit. I am looking to moving into the wireless flash side of things to give me more flexability but I do not know what to purchase to make this happen. Would I be right in thinking that the HVL-F42AM or HVL-F36AM would support both cameras and work with the HVL-F58AM?
Kind regards
Si
Hello Si, welcome to the Sony Forums
There's no compatibility issue with those flash units and either camera: http://esupport.sony.com/CA/perl/support-info.pl?template=&info_id=634
The F58 would be fine as controller for both F36 and F42.
Hope that's of some help
Mick
Mick
Just to add that if you use the a77 popup flash as a wireless controller, it will be fine for the first 15 shots but then the flash hangs and can only then trigger once every 10 seconds or so. When the camera goes into powersave briefly , the hang is removed and you can carry on. Hopefully this is a software bug that can be remedied.
Using the f58 as the controller, mounted on the a77 there is no such problem.
Thank you very much for you help Mick, that has cleared up a lot.
Si
