Hi, I've installed Sony Image Data Suite from the disk that came with the camera and tried using Remote Camera Control program that installed with it. Now when I start it there's a message saying:
Cannot detect the camera. Confirm that the camera is properly connected, and click OK.
I've tried in both USB modes. What am I doing wrong?
Thanks
Hi fudini
I'm pretty sure IDS only works with the Sony a700 and higher.
It won't recognise your camera as a compatible device, hence the lack of 'connection'.
Mick
Thanks Mick, lucky I don't really need this function.
