Have just bought above camera having traded in my Sony a 77 11. Have a F20AM flash gun which i used on my previous camera but the shoe on the new camera is not compatible. Dont want a big flash gun as would only use it occasionally. Anyone help with suggestions, please.
Thanks for that, Nobody had one in stock but ordered one from Sony Centre in Belfast and it came today and does the job.
Appreciate your help
Hi @brijan
You can easily find a compact flash on sony’s lineup https://www.sony.co.uk/camera-accessories/flashes-accessories?cpint=camera-accessories_product_finde...
If you are looking for alternative brand I highly suggest Godox that works great and have many options with lithium batteries (models with “S” at the end are the one compatible with sony)
