Sony Alpha A55 wide angle lens
profile.country.en_GB.title
bigal1974
Visitor
Has any one used this lens  Sony SAL-28F28 wide angle lens, if so is it any good it not which one is ?
1 REPLY 1
Watashiwateshdes
Contributor
Price vs performance it is very good but it depends on how wide you want to go. If you plan to use it for landscapes then yeah its pretty good but then if you have a 18-50, then that is wider so you might not ever find a use for this lens.
Its difficult to say which lens is suited for each user since everyone has an individual style.
I would honestly recommend visiting a local camera store before buying any lenses and trying some out yourself. Get your own opinions to ensure your money goes on the right lens.
You could also consider the SAL-1118
