I want to use A settings on my camera, but i want to control schutter speed. Is this possible on A7IV?
You can do all that you want.
What you mean with “A”?
If you mean “aperture” (as usually is) you can add the control if shutter speed switching to “M” (manual) where you can set both aperture and shutter speed.
If you mean “auto” than you can switch to S (shutter speed) to control directly the shutter and maintain aperture in auto.
It wasn’t clear before.
Maybe that you want to use auto-iso and set them the minimum shutter speed continuing to use A mode
