So I used my camera a week ago and it’s worked absolutely fine. Then a couple days ago I decided I’d back up everything from my memory card however my camera would not turn on. I tried plugging my camera in from the AC adapter but nothing. I then charged the battery in an external dock and it still won’t work. I’ve bought new batteries and they also won’t work. Has anyone had a similar issue and know a fix?
First: Same with and without SD card?
If so, best option is try a reset.
I can imagine the display isn't displaying.
Connect a HDMI cable from your camera to a monitor.
Use a HDMI to mini HDMI connector (5-10 euros)
Push the playback button which switches your camera on.
Push the menu button.
If you're lucky you can see the menu and find the option to reset your camera.
Do a reset.
I'm so sorry, it seems like it needs repair.
