Hi Guys,
Just bought a used Sony A6000. Just checked it is on the 2.00 software version
Want to update to 3.21 software but the camera did not come with any cables at all!
Which cable do I need to purchase that plugs into the bottom socket on the right hand side of the camera and then into my Mac Air.?
The cable is the minor of possible issues.
Use a good micro usb cable (like one from an old hard disk) and put on the “9”
https://helpguide.sony.net/gbmig/45349331/v1/en/contents/TP0000522400.html
The more is the compatibility with macos.. sony hate apple‘s devices 😓
You need for a
if not.. find a decent pc with windows 10, it’s all more easy
You need for a
