Hello bailey61 - Welcome to the Sony Forums
I cannot find any remote controls that appear to be compatible with this model. However, there is a third-party remote available on Amazon that claims to be compatible with the A330 and A380 - it may be worth getting in touch with the vendor to see if would also function with your A370.
The link is here:
http://www.amazon.co.uk/product-reviews/B002VM49KC/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
If it is not compatible, they may be aware of a product that will work with your model.
Thanks,
Simon
The link is here:
Thanks,
Simon
