Separate Battery Packs
SOLVED
profile.country.en_GB.title
davidGS
Visitor
Is it possible to buy a separate rechargable battery pack to use with DPF-D1020
I find that the supplied AC power source is inconveniently very short
David
1 ACCEPTED SOLUTION
Accepted Solutions
Mick2011
New
Hi David, welcome to the Sony Forums.
There's nothing listed on the Accessories page for that frame, unfortunately.
Have you considered using a simple power extension cord?
Mick
1 REPLY 1
Mick2011
New
Mick
