Want to check RAW files from camera are working OK before taking it on holiday shortly but no software update available yet from Capture One, Adobe, Luminar or Affinity possibly for 1-2 months. Does anyone know of a software that will handle these RAW files now. I use a MAC. Thanks
Thank you, After downloading a second file which the original requested I can see my RAW images and manipulate to a degree.
