I have recently downloaded some photos from facebook and subsequently uploaded to my DPF-D85. However the photo frame displays a question mark icon for all these images. Originally, the filenames were very long so I changed them to short alphanumeric filenames. Howevert the pictures still don't display.
I have read somewhere that the DPF-D85 does not display pictures created on a PC so I'm thinking perhaps this falls into that category. Why there is such a restriction I'm not sure(???), but does anyone know a way to get around this and to fix this issue.
Thanks!
Rob
Hi Rob, welcome to the Sony Forums
There's no restriction with PC-generated filenames as such, only that they dont exceed the accepted length and character set and aren't buried deep in a file subdirectory.
Make sure the images are in a top-level folder. Also make sure you have jpegs or tiffs, and that your filename is less than 10 characters long; ideally eight, in the form of IMAG1234.jpg
Let me know how you get on
Mick
Mick
found this info in the troubleshooting section, see attached:
