Hello!
I got the Timelapse app for my new nex-5r but is not fully satisfied because the auto-iso value is locked at the first image and when the sun comes and makes the enviroment brigther the images goes all white when the iso stayes at the higher value.
Is there any settings in the app to fix that or am i out of luck?
I bought the app to use it as an Intervalometer too so the light sometimes changes very rapidly.
Best regards Krusty
