Hi there,
I have recently bought another new card reader - my third - and yet again, after a few uses my computer fails to see it.
I am not sure if this is a fault with the laptop, the card or the card reader but I would like to try using a lead directly from the camera to the laptop.
Does anyone know which lead I need - even the guy in the Sony shop was not sure if it was a mini / micro USB or something else entirely. My camera is the DSLR a200.
Has anyone else had similar problems?
I don't use the camera much, and would definitely class myself as a beginner - and not great at technology! So any help massively appreciated.
Thanks, Jane
Hi Janewoodie and welcome to the Community!
You need a USB 2.0 cable for the Alpha 200, here's some examples
on Amazon: Click here although other retailers or even Ebay have them.
Thank you so much! Really appreciate your help.
Jane
No problem
