Paint.net looks like a great editing program (and it's free). Unfortunately It can't open my .arw files. Does anyone know if there is a codec available for this please?
Thanks in advance.
There is a RAW plugin for Paint.net available here: -
http://bstdownload.com/sdownload/paint.net+plugins+arw+raw/
However, I have not used it and it is up to you to check out the website.
Thanks for your quick response. Once I've appraised this I'll put my findings here.
