Does anybody know how compatible the Nex LA-EA1 is with sigma lenses ie autofocus/OS
afaik it only supports the following sony lenses and that's all
SAM lenses
DT 18-55mm F3.5-5.6 SAM [SAL1855]
28-75mm F2.8 SAM [SAL2875],
DT 55-200mm F4-5.6 SAM [SAL55200-2]
DT 30mm F2.8 Macro SAM [SAL30M28]
DT 35mm F1.8 SAM [SAL35F18]
DT 50mm F1.8 SAM [SAL50F18]
85mm F2.8 SAM [SAL85F28]
SSM lenses
Vario-Sonnar T* 16-35mm F2.8 ZA SSM [SAL1635Z]
Vario-Sonnar T* 24-70mm F2.8 ZA SSM [SAL2470Z]
Distagon T* 24mm F2 ZA SSM [SAL24F20Z]
70-200mm F2.8 G [SAL70200G]
70-300mm F4.5-5.6 G SSM [SAL70300G]
70-400mm F4-5.6 G SSM [SAL70400G]
300mm F2.8 G [SAL300F28G]
*Autofocus function is supported with these A-mount lenses
ref:
http://support.sony-europe.com/dime/downloads/downloads.aspx?f=FW_LAEA1_V02_WIN&site=odw_en_GB
SAM lenses
SSM lenses
ref:
