No.
I have the Sony A7R V, which is similar: it accepts CFexpress Type A memory card ONLY. One of the slots in the A7RV accepts CFexpress Type A, in the other slot I would use a UHS-II SD Card no less than the V60 version, possible the V90.
Hope this helps.
