Hi viadtheodor.
Have you checked in audio settings..:smileyconfused:
MENU button [Audio signals] Select the desired setting.
- Selects the sound produced when the shutter is locked, during self-timer countdown, etc.
Volume settings is locked.
I need to shoot photos in a very silent room.
Shutter sound is too loud and can not remove this.
You own an Alpha 33 from Sony !?
Unfortunately you will not be able to change the volume of the shutter as this is an actual mechanical sound..:smileysad:
