This is probably a very simple one for somebody, but I can't seem to find how to stop my slt a33 from going into movie playback when it is left on. I am fairly new to this camera but I am sure there must be a setting buried deep inside one of its menus. Does anyone know where?
I had the same problem with my Sony DSLR alpha 580, rang Sony support, they told me go into menu, move to the spanner icon, option 2, reset camera to default, guess what yes fixed it.
Dont know how I got to that situation in the first place but will watch out if it happens again.
Good luck
Good luck
Thanks for the advice (Sam1870), just reset camera and it seems to have sorted the problem!!!
