Hi Kev and welcome.
Have a look in your manual at "Shutter Priority" and "Aperture Priority". Pages 90 to 99.
To 'blurr' moving objects like water or cars, you need to use a slow shutter speed. Choose 'Shutter Priority' mode and set a slow shutter speed. Your Alpha will then choose the correct Aperture to give the correct exposure. The speed to set will depend on how quickly the object is moving - for a fast car 1/25 Sec will blurr the image. The same will apply to fast moving water, but for slower moving water you may need to use a slower speed and you will almost certainly need a tripod. Have a look at Page 94 of your manual.
Aperture Priority Mode allows you to set the f stop aperture value and the camera will automatically choose the correct shutter speed. If you choose the lowest f value (probably f 3.5) only objects close to the focusing distance will be clearly in focus but nearer and further objects will be blurred. If you choose a high F value (f16), the 'depth of field' wil be wider with more close and far objects in focus. Have a look at Page 92 of your manual.
Obviously, you are limited to the maximum and minimum values the camera can offer and you must always balance the Speed and Aperture.
Have a play around with these two settings and let us know how you get on. Don't be afraid to come back for more advice - there is no such thing as a silly question here!
I will have a look now,
Hi Kev and welcome.
