Hi I was wondering if anyone new of a battery grip which fitted the a390, I have seen a company on ebay but they look are coming from japan and the company looks a bit dodgy.
Thanks
The Alpha A390 is not compatible with any of the four Sony Vertical Grips.
http://esupport.sony.com/US/perl/support-info.pl?template=&info_id=637
I'm not sure I would trust a third party offering - especially on eBay.
Hi
I have just posted a similar note about a grip for my 290 and was wondering if you every found a compatable grip for your 390
