I want to use external microphones via the 3.5mm jack on my A7 camera. What is the input impedance?
Hey kgregory37962, it's not mentioned in the manual, but here are the compatible remotes.
https://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=eu&lang=en&mdl=ILCE...
Are you sure you have the alpha 7?
