I have a A500 dslr and have got myself a new laptop. I wanted to install the disc that came with the camera but can not find it. Dose anybody know if I can get a new one or download it?
if you follow the link below it will give you access to the downloadable software your require.
http://www.sony.co.uk/support/en/product/DSLR-A500/updates
Si
Si
here is the direct link to download origial supplied CD content:
http://www.sony.co.uk/support/en/product/DSLR-A500/downloads/download_manager
