I have had my Alpha 1 since the beginning of June. Tonight I was shooting after dark and turned the exposure compen sation dial to -3. It will not move from that position. I am pressing the centre button all the way, but nothing happens. Gently tapping does not help, nor does anything else I have tried.
Is there anything I can try apart from sending it off for repair?
Problem solved.
