On my new A7iv I had a strange experience yesterday.
Around 3 times when I tried to check my shots, I noticed that the files were playing with peaking.
After it was ok but without changing any settings at all. I have the latest firmware. I had 1.01 after 1.05 and the last 1.1. My cam was connected(multi-sony gamble) with my gimbal. Is it something to worry about?
Hi topssony, it might be a fault, but have you tried connecting Sony? http://bit.ly/3S7Vlue
Hello, please try it for you too...and inform me here!
By focusing on Spot focus (finger) and having Peaking ON/High, press play and check your shot!
I think you will have peaking on your playback too. I am waiting for your test! Thanks.
Thanks to all of you for the help... I was in a worry because I thought it was happening only on my cam.
My conclusion is that on Spot Focus the playback will have Peaking... but we can live with it. Thanks again.
