Hello,
The Audio jack input for A7iii camera is not working again. After getting it repaired after less than a year from buying it, it has again gone faulty. This is a clear defect and makes this camera not suitable for video work. What is the solution now? Spending another £250 to get it fixed?!!!
Hey Sellami, try the basics, removing the battery, updating, or resetting it. If it's a physical fault, it's not covered even within the warranty. So yes, the only solution is to send it for repair.
