https://helpguide.sony.net/cam/1640/v1/en/contents/TP0000960294.html
Hint
Manolo
ah so no way of getting around it i assume
Hello @robert90903,
unfortunately the limit is there, since some SD-cards can't handle significantly more files than fourty thousand.
There are a few trick though: https://www.reddit.com/r/sonyactioncam/comments/9hdktk/getting_rid_of_40k_max_photo_limit_on_x3000/
- Nic
